squirley174
#1 Posted : Wednesday, November 26, 2008 5:30:01 PM(UTC)
squirley174
I recently received a new freezer door gasket for the above model and brand. However, here are no instructions on how to install it. Can you walk me through the process so I don't mess up the door.
Also, the end caps I received don't seem to fit tightly on the first shelf bar on the refrigerator door. The P/N is: 67213-2. I'm afraid because it won't hold properly the stuff on the shelf is going to fall off and break. What is the solution.
Thank you, Shirley Lance
v2k04
#2 Posted : Wednesday, November 26, 2008 6:26:29 PM(UTC)
v2k04
oh boy!! .. first lay out the gasket on the floor and get all the wrinkles out of it. Use a hair dryer until it is relativly straight dont get it to hot or to close cuz you'll melt it another way is running it under hot water to remove wrinkles get that done first and let us know
squirley174
#3 Posted : Thursday, November 27, 2008 4:24:46 AM(UTC)
squirley174
Is it that difficult? Should I have a repair man do it? What about the end cap issue?
v2k04
#4 Posted : Thursday, November 27, 2008 4:34:12 AM(UTC)
v2k04
yes it is you can't just slap the gasket on and expect the door to close on the first try sometimes it takes a lot of adjusting to get it right I cant tell by the diagram what kind of end caps you have I would call a repairman have him do the gasket and tell you whats wrong with the endcaps.
GracieC74
#5 Posted : Tuesday, January 6, 2009 12:43:36 PM(UTC)
GracieC74
I just replaced my refrigerator door gasket and I can't get it to seal all the way around. The top of the right side seals but the bottom has to be pushed in to get the seal. The top has a few spots that are not, but the hinged side is sealed all the way. I can not see whether the bottom is sealed or not. Is there something I have to put on the gasket or is it just not aligned properly? Thanks
upright freezer frosting/icing after gasket replacement (Refrigerator & Freezer Repair)
by woakley 9/30/2019 7:09:57 AM(UTC)
LG fridge door gasket replacement - french doors (Refrigerator & Freezer Repair)
by bcarroll7 7/28/2019 11:14:38 AM(UTC)
Gasket replacement for Imperial freezer (Refrigerator & Freezer Repair)
by bdcane 9/3/2017 8:38:37 AM(UTC)
Door Gasket replacement (Refrigerator & Freezer Repair)
by mlbmark 12/6/2012 4:38:53 PM(UTC)
Front Loader gasket replacement (Washer Repair)
by maduro858 12/11/2011 7:22:43 PM(UTC)
Refrigerator door gasket replacement (Refrigerator & Freezer Repair)
by Tom Carty 6/23/2011 9:22:00 AM(UTC)
Fridgerator door gasket replacement (Refrigerator & Freezer Repair)
by plumber365 1/25/2011 5:50:02 PM(UTC)
Front Rubber Gasket replacement (Washer Repair)
by cbonasera 9/26/2010 11:43:22 AM(UTC)
Whirlpool Oven Gasket Replacement (Oven Repair (including Ranges and Cooktops))
by dwell 8/18/2010 8:03:46 AM(UTC)
Bottom freezer door gasket replacement (Refrigerator & Freezer Repair)
by PageinSC 7/18/2010 7:42:53 AM(UTC)
by grenoble 4/9/2010 7:23:57 AM(UTC)
HE3T Door gasket replacement (Washer Repair)
by gbramhall 1/13/2010 3:41:41 PM(UTC)
ap4010226 gasket replacement (Washer Repair)
by RINKYDINKS 1/2/2010 4:38:27 PM(UTC)
Tub Gasket Replacement Help (Washer Repair)
by jrussell_75423 12/22/2009 9:37:42 AM(UTC)
freezer gasket replacement (Refrigerator & Freezer Repair)
by cleaver 12/15/2009 12:27:21 PM(UTC)
