jmltoyo
#1 Posted : 16 years ago
jmltoyo
My broiler will not heat up. This also will not allow the self cleaning to work. I checked all connections, some were loose, but after tightening, it still is not working. The element itself looks ok. I checked the resistance of the element and it checked out ok. I am assuming the problem is in the electronic clock control for this model. Any suggestions?
SublimeMasterJW
#2 Posted : 16 years ago
SublimeMasterJW
The electronics get damaged from self clean mode. The heat is just too much. You probably have a bad control.
