jmltoyo
#1 Posted : Sunday, November 23, 2008 6:16:57 AM(UTC)
jmltoyo
My broiler will not heat up. This also will not allow the self cleaning to work. I checked all connections, some were loose, but after tightening, it still is not working. The element itself looks ok. I checked the resistance of the element and it checked out ok. I am assuming the problem is in the electronic clock control for this model. Any suggestions?
SublimeMasterJW
#2 Posted : Sunday, November 23, 2008 8:41:34 AM(UTC)
SublimeMasterJW
The electronics get damaged from self clean mode. The heat is just too much. You probably have a bad control.
Guest (4)
