federicokiki
#1 Posted : Saturday, November 22, 2008 11:21:00 AM(UTC)
federicokiki
My washer will fill, agitate, rinse and drain but it won't spin!! I'm assuming the lid switch works because it wont agitate with the lid up but if you press the lid switch down it runs fine. When it comes to the spin cycle i used to be able to get it started by hand and it would spin at about half speed now its totally dead in the water. I checked the motor coupler, looks practically brand new. Everything sounds like its running as far as the motor and everything goes but if you lift the lid during the spin cycle the tub is not moving. I've already changed out the timer and it worked fine for a week but then we were back to the same problem.
Please advise.
libertyappl
#2 Posted : Saturday, November 22, 2008 11:24:08 AM(UTC)
libertyappl
That's probably your clutch.
Nat
Maytag Spin Cycle Not Working & Making Loud Ratcheting Sound (Washer Repair)
by josh9676 10/8/2015 6:56:00 PM(UTC)
GE Washer Spin Cycle not Working (Washer Repair)
by jmoconn 3/31/2015 6:28:49 AM(UTC)
Spin cycle not working (Washer Repair)
by thomhee 1/2/2015 7:43:12 AM(UTC)
Spin Cycle Not Working (Washer Repair)
by pastord24 9/1/2014 7:19:09 AM(UTC)
Wash cycle OK, spin cycle not working (Washer Repair)
by Jesse49 10/17/2012 6:38:33 AM(UTC)
by silvia769 7/31/2012 6:52:55 AM(UTC)
Spin cycle not working properly (Washer Repair)
by dngirard 7/30/2012 9:32:01 AM(UTC)
by Mr.GP 5/4/2012 3:04:03 PM(UTC)
by Patti Fagan 1/23/2012 8:27:23 AM(UTC)
Final Spin Cycle Not Working (Washer Repair)
by todd granbois 8/7/2011 6:51:44 AM(UTC)
by nikki777 11/17/2010 6:33:20 PM(UTC)
Spin Cycle not working properly (Washer Repair)
by BrokeinNC 10/23/2010 8:07:37 AM(UTC)
Kenmore Washer - Agitator and spin cycle not working (Washer Repair)
by hochhaus99 5/11/2010 12:39:54 PM(UTC)
only spin cycle not working (Washer Repair)
by biosdude 2/17/2010 8:12:03 PM(UTC)
by jonb89 2/12/2010 9:30:03 AM(UTC)
