My washer will fill, agitate, rinse and drain but it won't spin!! I'm assuming the lid switch works because it wont agitate with the lid up but if you press the lid switch down it runs fine. When it comes to the spin cycle i used to be able to get it started by hand and it would spin at about half speed now its totally dead in the water. I checked the motor coupler, looks practically brand new. Everything sounds like its running as far as the motor and everything goes but if you lift the lid during the spin cycle the tub is not moving. I've already changed out the timer and it worked fine for a week but then we were back to the same problem. Please advise.
That's probably your clutch.
Nat
