Jesse49
#1 Posted : Wednesday, October 17, 2012 6:38:33 AM(UTC)
Jesse49
Older Kenmore washer, wash cycle OK, spin cycle not working, drains water OK. Checked clutch, OK; brake pads OK, motor coupler OK. Re-assembled after adding 90 oil to gear case, spin cycle OK without cloth in tub. Added a load to wash, wash cycle OK spin cycle did not work once again, you think is the gear assembly??
Simon / APP Team
#2 Posted : Wednesday, October 17, 2012 1:07:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First check the drive block (you will have to remove the agitator).
If it's not cut through then replace the clutch Part number: 285785
Part number: 285785
Post the results.
Simon.
