Older Kenmore washer, wash cycle OK, spin cycle not working, drains water OK. Checked clutch, OK; brake pads OK, motor coupler OK. Re-assembled after adding 90 oil to gear case, spin cycle OK without cloth in tub. Added a load to wash, wash cycle OK spin cycle did not work once again, you think is the gear assembly??
Groups: APP Team
Hi. First check the drive block (you will have to remove the agitator). If it's not cut through then replace the clutch Part number: 285785
Post the results. Simon.
