Cook top works fine but oven will not turn on. Is there a fuse or thermostat that controls this function. I do not have a parts schematic or listing to go by to see what parts could be bad. Any help would be appreciated! Thanks
The model number you posted is incomplete. Verify and repost it please.
This model number does not come up. The closest model number I found is JGBP24GEJ2. Per this model number the range is gas. Is this correct?
That is correct, it is a gas oven.
Originally Posted by: Gene  This model number does not come up. The closest model number I found is JGBP24GEJ2. Per this model number the range is gas. Is this correct?
Gene. I have a similar problem with a GE Oven JGBC15GER4WH Itjust will not come on. How do you determine which part is bad?
Originally Posted by: Xray  That is correct, it is a gas oven. Check if there is 120 VAC to the Bake igniter (#718 on the diagram) while the control calls for Bake. If the voltage reading is correct, replace the igniter. - The oven Bake igniter Part number: AP2009619
Originally Posted by: jwsbillie  I have a similar problem with a GE Oven JGBC15GER4WH Itjust will not come on. How do you determine which part is bad? Even your range is different you still can use the same instructions as Xray. - The oven igniter Part number: AP2014008
Will check to see if we are getting 120vac and then order ignitor if needed. Thanks, Greg
Originally Posted by: Gene  Even your range is different you still can use the same instructions as Xray. - The oven igniter Part number: AP2014008
Thanks, Gene. I will check the voltage and order an igniter if the voltage is ok. Bill(jwsbillie)
