Xray
#1 Posted : Monday, December 20, 2010 11:06:56 AM(UTC)
Xray
Cook top works fine but oven will not turn on.
Is there a fuse or thermostat that controls this function.
I do not have a parts schematic or listing to go by to see what parts could be bad.
Any help would be appreciated!
#2 Posted : Monday, December 20, 2010 12:40:05 PM(UTC)
The model number you posted is incomplete. Verify and repost it please.
Xray
#3 Posted : Monday, December 20, 2010 1:04:33 PM(UTC)
Xray
Model number JGBP24EJH2
#4 Posted : Monday, December 20, 2010 7:16:42 PM(UTC)
This model number does not come up. The closest model number I found is JGBP24GEJ2. Per this model number the range is gas. Is this correct?
Xray
#5 Posted : Tuesday, December 21, 2010 6:01:17 AM(UTC)
Xray
That is correct, it is a gas oven.
jwsbillie
#6 Posted : Tuesday, December 21, 2010 6:51:26 AM(UTC)
jwsbillie
I have a similar problem with a GE Oven JGBC15GER4WH Itjust will not come on. How do you determine which part is bad?
#7 Posted : Tuesday, December 21, 2010 1:35:56 PM(UTC)
Check if there is 120 VAC to the Bake igniter (#718 on the diagram) while the control calls for Bake.
If the voltage reading is correct, replace the igniter.
- The oven Bake igniter Part number: AP2009619
#8 Posted : Tuesday, December 21, 2010 1:38:58 PM(UTC)
Even your range is different you still can use the same instructions as Xray.
- The oven igniter Part number: AP2014008
Xray
#9 Posted : Tuesday, December 21, 2010 2:08:15 PM(UTC)
Xray
Will check to see if we are getting 120vac and then order ignitor if needed.
Thanks,
Greg
jwsbillie
#10 Posted : Wednesday, December 22, 2010 5:10:16 AM(UTC)
jwsbillie
Thanks, Gene. I will check the voltage and order an igniter if the voltage is ok.
Bill(jwsbillie)
Fridgidair oven will not come on (Oven Repair (including Ranges and Cooktops))
by dbell1967 8/18/2013 8:17:08 AM(UTC)
Roper oven will not come on (Oven Repair (including Ranges and Cooktops))
by buttacis 1/27/2009 2:52:00 PM(UTC)
by Bobby Giley 11/21/2008 1:03:02 PM(UTC)
