Cook top works fine but oven will not turn on. Is there a fuse or thermostat that controls this function. I do not have a parts schematic or listing to go by to see what parts could be bad. Any help would be appreciated! Thanks
Rank:: Advanced Member
Groups ready for retrieval: Senior Expert, Administrators Joined: 7/19/2007(UTC) Posts: 27,455
The model number you posted is incomplete. Verify and repost it please.
This model number does not come up. The closest model number I found is JGBP24GEJ2. Per this model number the range is gas. Is this correct?
That is correct, it is a gas oven.
Originally Posted by: Gene  This model number does not come up. The closest model number I found is JGBP24GEJ2. Per this model number the range is gas. Is this correct?
Gene. I have a similar problem with a GE Oven JGBC15GER4WH Itjust will not come on. How do you determine which part is bad?
Originally Posted by: Xray  That is correct, it is a gas oven. Check if there is 120 VAC to the Bake igniter (#718 on the diagram) while the control calls for Bake. If the voltage reading is correct, replace the igniter. - The oven Bake igniter Part number: AP2009619
Originally Posted by: jwsbillie  I have a similar problem with a GE Oven JGBC15GER4WH Itjust will not come on. How do you determine which part is bad? Even your range is different you still can use the same instructions as Xray. - The oven igniter Part number: AP2014008
Will check to see if we are getting 120vac and then order ignitor if needed. Thanks, Greg
Originally Posted by: Gene  Even your range is different you still can use the same instructions as Xray. - The oven igniter Part number: AP2014008
Thanks, Gene. I will check the voltage and order an igniter if the voltage is ok. Bill(jwsbillie)
