The range burners ignite fine, the broiler works fine but the oven will not ignite. The glow bar is bright orange but it is not igniting. If I open the door and light a stove top burner the oven ignites. But once it reaches temp and turns off it will not reignite to get the temp back up. PLEASE HELP.
Tracy H
Tracy,
Sounds like the oven Bake igniter has gone bad (weak).
If you need the correct part number, post the complete model number of the range. XL44 is not a valid model number.
