2 Pages12>
jeff42
#1 Posted : Thursday, November 20, 2008 7:28:09 AM(UTC)
jeff42
refrigerator not getting cold and the freezer freezing and not defrosting, went to appliance store they told us it could be thermostat or some kind of switch.... Also it sounds like it wants to run but hesitates...
libertyappl
#2 Posted : Thursday, November 20, 2008 7:36:01 AM(UTC)
libertyappl
Look on the rear wall of the freezer. Do you see a lot of frost or ice buildup?
It sounds like a defrost issue.
Nat
jeff42
#3 Posted : Thursday, November 20, 2008 12:23:17 PM(UTC)
jeff42
there is frost buildup but the freezer acts like it is working good other than the frost, the fridge part is not getting very cold and it is turned up...
libertyappl
#4 Posted : Thursday, November 20, 2008 12:27:36 PM(UTC)
libertyappl
Turning it up won't help it. Your frig is having a defrost problem.
Here's the parts breakdown on your unit Model RT18BKXKQ00
You need to test the adaptive defrost timer and defrost thermostat to see which one or if both aren't working properly.
Nat
jeff42
#5 Posted : Thursday, November 20, 2008 1:01:15 PM(UTC)
jeff42
how would you go about testing that , sorry i know nothing about this kind of stuff....
libertyappl
#6 Posted : Thursday, November 20, 2008 1:18:29 PM(UTC)
libertyappl
Here's your tech sheet it shows the steps to enter test mode. http://servicematters.co...s/wiring/wiring_main.htm
If that doesn't come up for you, your tech sheet should be in your unit, near the compressor or behind the kick plate.
Nat
jeff42
#7 Posted : Friday, November 21, 2008 6:57:13 PM(UTC)
jeff42
i tried option 2 i did hear a click once any suggestions on what i can do next or should i go ahead and try option 1.... thanks
libertyappl
#8 Posted : Friday, November 21, 2008 7:00:36 PM(UTC)
libertyappl
Can you hear the unit defrosting? i.e. ice popping and cracking. Is the compressor and fans running now?
nat
jeff42
#9 Posted : Friday, November 21, 2008 7:01:29 PM(UTC)
jeff42
where do you check for defrost heat in the freezer or where? i did hear one click when i was in the test mode...
jeff42
#10 Posted : Friday, November 21, 2008 7:03:03 PM(UTC)
jeff42
i can hear the freezer running i dont know if it defrosting or not, i did that option 2 on the tech sheet...
Refrigerator Repair Services In Dubai (Refrigerator & Freezer Repair)
by superfix appliances 11/14/2021 12:50:05 AM(UTC)
Refrigerator repair (Refrigerator & Freezer Repair)
by ppudelek 1/27/2016 10:42:58 AM(UTC)
Refrigerator repair next step (Refrigerator & Freezer Repair)
by blinder 9/25/2014 7:16:50 AM(UTC)
refrigerator repair question (Refrigerator & Freezer Repair)
by tlavacque 8/31/2013 10:25:56 AM(UTC)
Haier Mini Refrigerator Repair (Refrigerator & Freezer Repair)
by milesdavis88 7/30/2013 1:52:48 PM(UTC)
Refrigerator Repair Question (Refrigerator & Freezer Repair)
by allantag 8/24/2012 10:17:04 AM(UTC)
refrigerator repair (Refrigerator & Freezer Repair)
by dweston1@q.com 10/13/2011 7:27:52 AM(UTC)
Whirlpool Top Freezer & Refrigerator Repair or Replace? (Refrigerator & Freezer Repair)
by mmossorgin 9/8/2011 7:54:36 PM(UTC)
"need Help With Refrigerator Repair" (Refrigerator & Freezer Repair)
by bh1962m 7/6/2011 8:13:06 AM(UTC)
GE Refrigerator Repair Question (Refrigerator & Freezer Repair)
by jgolfaholic 5/17/2011 7:59:47 PM(UTC)
Kitchen Aid Refrigerator Repair (Refrigerator & Freezer Repair)
by KitchenAidRefrigerator 4/7/2011 8:57:37 AM(UTC)
Subzero Refrigerator repair for 201R (Refrigerator & Freezer Repair)
by dville 9/8/2010 8:05:09 AM(UTC)
by abradeaton 5/3/2010 9:55:57 AM(UTC)
by hg2085 1/11/2010 8:33:03 AM(UTC)
Refrigerator repair question (Refrigerator & Freezer Repair)
by bthlonewolf 9/12/2009 8:24:28 PM(UTC)
2 Pages12>
