Anthony S.
#1 Posted : Saturday, November 15, 2008 8:30:51 AM(UTC)
Anthony S.
My washer is not moving at all. It will drain and fill, but it will not wash or spin. I can here a loud humming and clicking noise coming from the timer area. I just recetnly replaced the motor and it still is not working. Any ideas on where I should focus next?
Thanks,
Anthony
v2k04
#2 Posted : Saturday, November 15, 2008 8:41:21 AM(UTC)
v2k04
"Motor controller" It usually goes out more often than the timer check the data sheet for diagnostics on it
Anthony S.
#3 Posted : Saturday, November 15, 2008 9:03:06 AM(UTC)
Anthony S.
Are you referring to the Speed Control Board?
Also, I am not sure what Data sheet I am supposed to look at, can you send me in the right direction?
Thanks again,
Anthony
v2k04
#4 Posted : Saturday, November 15, 2008 9:31:56 AM(UTC)
v2k04
It's taped to the lower washer panel inside or stuck to the inside side panel
Frigidare Front Loader Not Washing (Washer Repair)
by Anthony S. 10/22/2008 10:26:49 AM(UTC)
