My washer is not moving at all. It will drain and fill, but it will not wash or spin. I can here a loud humming and clicking noise coming from the timer area. I just recetnly replaced the motor and it still is not working. Any ideas on where I should focus next?
Thanks, Anthony
"Motor controller" It usually goes out more often than the timer check the data sheet for diagnostics on it
Originally Posted by: v2k04  "Motor controller" It usually goes out more often than the timer check the data sheet for diagnostics on it Are you referring to the Speed Control Board? Also, I am not sure what Data sheet I am supposed to look at, can you send me in the right direction? Thanks again, Anthony
It's taped to the lower washer panel inside or stuck to the inside side panel
