jpcalkins
#1 Posted : 18 years ago
jpcalkins
Drain hose for washer is leaking where it connects to the base of the drum. The hose does not have a hole in it. Is there something that is supposed to be on top of that hose to help it seal? Seems to be some sort of orange caulking or something that is peeling off.
#2 Posted : 18 years ago
I would replace the wire clamp with an adjustable steel one available anywhere.
frigidaire washer leaking under (Dishwasher Repair)
by uzgut 14 years ago
Frigidaire washer leaking out bottom (Washer Repair)
by firedancer 14 years ago
Frigidaire Washer Leaking Water From Front (Washer Repair)
by sdsprigler 14 years ago
frigidaire washer leaking (Forum Announcements)
by marcm45 16 years ago
