dryer was working fine went to use it again and light in door works but dryer will not turn on, any ideas? thanks
Originally Posted by: snooki  dryer was working fine went to use it again and light in door works but dryer will not turn on, any ideas? thanks dryer is less than3 yrs old and have always kept the lint screen clean and free from waxy buildup
A model number may help others help you.
Many units have a thermal fuse mounted on the blower wheel this is a common cause of your symptom.
If it is blown check/clean your vent system as it is the most common cause of this fuse blowing. |
THIS FORUM IS DEAD!!!!!!! |
