my kenmore stack washer /dryer is having problems. It wont turn on, only humms upon turning starting switch. replaced motor last month. worked previously where do I start for trouble shooting? motor good, timer good, start switch good, heat coils good. whats next?
I would open it back up and make sure you belt is on correctly and everything inside is as it should be. (Just this morning I put one back together and the belt slipped off the motor pulley and hung things up) After you get it back together make sure the drum will turn easily by hand.
