repairman5017
#1 Posted : Friday, November 14, 2008 5:31:12 AM(UTC)
repairman5017
The broiler burner worked until I replaced burned out igniter on bake burner. Now both igniters glow and stay on but neither ignite.
#2 Posted : Friday, November 14, 2008 11:38:47 AM(UTC)
Did you close the gas line prior to this repair? If you did, check if it's open.
P.S. What is the complete model number of the oven?
abadfish66
#3 Posted : Friday, November 14, 2008 11:41:39 AM(UTC)
abadfish66
Also, you may have bumped the lever on the regulator, if it's down flip it up.
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
GE Oven Control board locking after starting oven. Model # CGS985SETASS (Oven Repair (including Ranges and Cooktops))
by Mike I 1/15/2024 10:55:45 PM(UTC)
GE oven bake element (Oven Repair (including Ranges and Cooktops))
by 72yrsoldwoman 10/27/2023 6:22:03 PM(UTC)
Frigidaire Gallery Range Oven Won't Get to Temp (Oven Repair (including Ranges and Cooktops))
by Guest 5/5/2023 7:41:56 PM(UTC)
Amana range oven elements stopped working (Oven Repair (including Ranges and Cooktops))
by Primary123 6/8/2022 1:40:04 PM(UTC)
Monogram Range Oven Mod ZGP486LDR4SS (General Talk)
by astringfield 12/29/2021 4:58:36 AM(UTC)
GE gas range oven won’t come on (Oven Repair (including Ranges and Cooktops))
by Guest 6/6/2021 3:02:24 PM(UTC)
Viking range ovens, broiler, and griddle don’t turn on (Oven Repair (including Ranges and Cooktops))
by Guest 5/19/2021 11:02:20 AM(UTC)
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by Guest 5/10/2021 12:58:16 PM(UTC)
Phantom GE Oven Model (Oven Repair (including Ranges and Cooktops))
by pervis 4/25/2021 2:16:40 AM(UTC)
GE Oven - touch pad problem (Oven Repair (including Ranges and Cooktops))
by tinamonsaas 12/2/2020 7:23:09 PM(UTC)
Norge Oven Timer preventing the oven from working (Oven Repair (including Ranges and Cooktops))
by Stilltrying2 10/10/2020 1:37:47 PM(UTC)
GE Oven Tuns Off Randomaly (Oven Repair (including Ranges and Cooktops))
by gregciccol 8/9/2020 10:08:42 AM(UTC)
