The broiler burner worked until I replaced burned out igniter on bake burner. Now both igniters glow and stay on but neither ignite.
Did you close the gas line prior to this repair? If you did, check if it's open.
Gene. P.S. What is the complete model number of the oven?
Also, you may have bumped the lever on the regulator, if it's down flip it up.
