cwilbur
#1 Posted : Thursday, November 13, 2008 9:51:33 AM(UTC)
cwilbur
The ice make will make several batches of ice with no problem. The ice forms, slides off onto the cube grate and then melts into cubes. This goes on for several hours and the bin gets about 1/3 full, then it starts making a noise as though it is having trouble pumping . The problem is that now there is a large build up of ice on the freeze plate and water is running over it. I can turn the unit off until the ice melts and then start it back up and it will repeat the above. Something is causing the sheet of ice to not drop and therefore it begins to build. Can anyone help? Thanks, Charlie
libertyappl
#2 Posted : Thursday, November 13, 2008 11:13:58 AM(UTC)
libertyappl
Please post your model number. You might try some ice machine cleaner.
Nat
MFX2876DRM02 Maytag fridge ice build up (Refrigerator & Freezer Repair)
by HOOBI 11/27/2018 12:09:49 PM(UTC)
Freezer too cold, Ice build up causing leak (Refrigerator & Freezer Repair)
by Sgibb16 4/23/2018 9:12:33 PM(UTC)
Ice build up on kenmore, tested heater and thermostat (Refrigerator & Freezer Repair)
by artpac2004 1/9/2018 4:52:18 PM(UTC)
ice build up on food side (Refrigerator & Freezer Repair)
by richard203 5/16/2017 2:28:17 PM(UTC)
Ice build up on outside back (Refrigerator & Freezer Repair)
by fireflynj 12/8/2016 9:13:42 AM(UTC)
Fridgidaire Gallery: Fresh Food Ice maker not defrosting. Heavy ice build up (Refrigerator & Freezer Repair)
by Sev 5/10/2016 5:48:09 AM(UTC)
Whirlpool Diffuser ice build up (Refrigerator & Freezer Repair)
by Tgaito 7/31/2015 4:02:32 PM(UTC)
Samsung fridge ice build up back wall (Refrigerator & Freezer Repair)
by RTGsauce 7/15/2015 1:59:31 PM(UTC)
GE Cafe Refrigerator not cooling properly/ice build up inside by vents (Refrigerator & Freezer Repair)
by september22 6/1/2015 11:16:31 AM(UTC)
Ice build up bottom of the freezer and water leaking the front door unto the floor (Refrigerator & Freezer Repair)
by BEbner 5/22/2015 1:56:55 PM(UTC)
Kitchenaid Ice Build up in drain tray. (Refrigerator & Freezer Repair)
by Pjrs 5/3/2015 9:42:02 AM(UTC)
Ice build up in freezer (Refrigerator & Freezer Repair)
by margiotta@juno.com 4/13/2015 2:09:27 PM(UTC)
Not Cooling - Fan Running, No Ice Build Up, Compressor Quiest (Refrigerator & Freezer Repair)
by Odjur 3/20/2015 2:47:04 PM(UTC)
ice build up-temp control (Refrigerator & Freezer Repair)
by odegrees 11/27/2014 5:29:59 AM(UTC)
ice build up on freezer bottom (Refrigerator & Freezer Repair)
by Paddab 8/6/2014 5:37:33 AM(UTC)
