Legatus
#1 Posted : Thursday, November 25, 2010 4:44:37 PM(UTC)
Legatus
As the tile says washer will not agitate or spin. The machine makes a buzz or hum during agitate or spin but the motor does not move. Belt is fine, motor and basket turn smoothly by hand. First test with meeter shows correct voltage coming into board at harness. Second test of timer harness all readings are off. Motor ohms at 3.8, manual says it should be 2.6 +- 7%. The manual is not clear what is wrong when some of the meter tests fail.
#2 Posted : Friday, November 26, 2010 7:01:29 AM(UTC)
Try unplugging/plugging connectors, a pin may be loose. You can also use non-residue contact cleaner on them.
Washer will not spin or agitate (Washer Repair)
by larrylyons 9/7/2013 1:11:10 PM(UTC)
GE washer will not spin or agitate (Washer Repair)
by tarzandude43 12/18/2012 9:05:54 PM(UTC)
Kenmore 70 series washer will not spin or agitate (Washer Repair)
by boseman75 8/5/2012 2:45:56 PM(UTC)
by Mike442 5/13/2012 11:32:49 AM(UTC)
Maytag style top loading washer will not spin or agitate (Washer Repair)
by Mike442 5/10/2012 6:20:11 PM(UTC)
Washer will not spin or agitate, but fills & drains (Washer Repair)
by Bama Girl 3/3/2012 8:08:41 AM(UTC)
by Jaosn 9/21/2011 5:42:03 AM(UTC)
by nemecj 6/27/2011 12:48:18 PM(UTC)
Washer will not spin or agitate, but drains (Washer Repair)
by coaner 5/17/2011 11:17:09 AM(UTC)
Ge washer will not spin or agitate (Washer Repair)
by Paul Di 3/25/2011 3:02:25 PM(UTC)
by bfreeman91080 1/13/2010 9:15:50 AM(UTC)
by negron 1/10/2010 1:14:57 PM(UTC)
GE Washer will not spin or agitate (Washer Repair)
by casshley 11/6/2009 6:00:06 AM(UTC)
by frankie15oct 7/6/2009 2:22:08 PM(UTC)
by sjjohnson 3/21/2009 10:06:00 AM(UTC)
