dryer will not start, all items checks ok, including the one time use thermal fuse, has continuity.
Check to be sure you have 240 volts at the plug. Sometimes half the line can drop out without tripping the breaker. Turn the breaker off/on a couple times slowly.
Then I would check the door switch. |
THIS FORUM IS DEAD!!!!!!! |
