The dryer heats & fan blows but won't spin... I have taken the back off to try to see the belt... but looks to me like I have to completely disassemble the dryer... is there a better way to the motor/belt? Is there a description manual l or sheet that I can get online? Thanks
I Can't Pull Up That Model Number You Posted, But Your Should Be Able To Raise The Top And Remove The Front Panel To Access The Belt.
Nat
Originally Posted by: libertyappl  I Can't Pull Up That Model Number You Posted, But Your Should Be Able To Raise The Top And Remove The Front Panel To Access The Belt.
Nat I got it!!! thanks...Is there a diagram for replacing the broken belt
