wvogel57
#1 Posted : Friday, November 19, 2010 8:49:10 AM(UTC)
wvogel57
I am noticing water on the floor in front of refrigerator probably on deforst cycle
Joe / APP Team
#2 Posted : Friday, November 19, 2010 12:01:17 PM(UTC)
Joe / APP Team
WV,
It could be a crack in the defrost drain pan, if you've moved the fridge recently,
You should remove the front kick plate / grille from the bottom of the front of the fridge, and look for water in the drain pan.
Most likely what you would check for and find , is a loose connection on the water dispenser fill tube double connector behind the grille and clipped up to the base frame of the freezer compartment.
Also check the fill tube where it comes out at the bottom of the door.
Good Luck,
Kenmore Refrigerator Pooling Water on Floor (Refrigerator & Freezer Repair)
by vintess 2/17/2017 5:18:47 PM(UTC)
Refrigerator water on floor (Refrigerator & Freezer Repair)
by kruegerbest 6/1/2015 10:13:31 AM(UTC)
Water on floor (Refrigerator & Freezer Repair)
by bstreyle2 1/19/2015 5:35:06 PM(UTC)
whirlpool cabrio displays ul code and spills water on floor (Washer Repair)
by dirtman 13 7/29/2012 8:06:36 PM(UTC)
Ice in bottom of my LG freezer & water on floor (Refrigerator & Freezer Repair)
by dutchreagan 4/5/2012 6:46:53 AM(UTC)
Refridgerator leaking water on floor (Refrigerator & Freezer Repair)
by greg2012 8/27/2011 6:54:45 AM(UTC)
Refrigerator - Water on Floor, Repairing a Clogged Defrost Drain (Refrigerator & Freezer Repair)
by mousavi2011 3/25/2011 10:25:25 AM(UTC)
Bosch Dishwasher, Water on Floor (Dishwasher Repair)
by gourso 2/15/2011 9:08:30 AM(UTC)
Kitchenaid leaking water on floor (Refrigerator & Freezer Repair)
by mjslord 7/30/2010 8:10:10 AM(UTC)
Defrost water on floor (Refrigerator & Freezer Repair)
by sushil 4/25/2010 7:02:11 AM(UTC)
Freezer ice buildup and water on floor (Refrigerator & Freezer Repair)
by Kat Stahl 4/3/2010 8:49:48 PM(UTC)
Balance Ring hitting Ring Tub and water on floor (Washer Repair)
by mrwto 1/26/2010 1:34:37 PM(UTC)
Water on floor/clicking noise in rear (Refrigerator & Freezer Repair)
by eorcdave 8/22/2009 10:10:34 AM(UTC)
Water on floor in front of refrigerator. (Refrigerator & Freezer Repair)
by joeblue 8/19/2009 7:07:50 AM(UTC)
by richard72 8/9/2009 2:39:34 PM(UTC)
