Hello Ya'll, my dryer won't heat up. The ignitor comes on for about 5 seconds then goes out. I order, from you guys, and replaced the gas valve coils, no help. I check the Igintor it is less then 100 ohms. I also check the flame sensor and it has continutiy. Not sure where to go from here, any help at all. Thanks....
Originally Posted by: timmyd4  Hello Ya'll, my dryer won't heat up. The ignitor comes on for about 5 seconds then goes out. I order, from you guys, and replaced the gas valve coils, no help. I check the Igintor it is less then 100 ohms. I also check the flame sensor and it has continutiy. Not sure where to go from here, any help at all. Thanks.... Timmy, You are sure you have gas to the gas valve ? You may want to remove the valve, remove the burner orifice, and check for a clog(spider web) inside the orifice and valve body. If those all check OK, I would have to think, you've got a mechanical failure inside the gas valve. Part number: AP3094298
Good Luck, :cool: :cool: :cool:
