Tim
timmyd4
#1 Posted : Friday, November 19, 2010 8:09:12 AM(UTC)
timmyd4
Hello Ya'll, my dryer won't heat up. The ignitor comes on for about 5 seconds then goes out. I order, from you guys, and replaced the gas valve coils, no help. I check the Igintor it is less then 100 ohms. I also check the flame sensor and it has continutiy. Not sure where to go from here, any help at all. Thanks....
Joe / APP Team
#2 Posted : Friday, November 19, 2010 8:46:38 AM(UTC)
Joe / APP Team
Timmy,
You are sure you have gas to the gas valve ?
You may want to remove the valve, remove the burner orifice, and check for a clog(spider web) inside the orifice and valve body.
If those all check OK,
I would have to think, you've got a mechanical failure inside the gas valve.
Part number: AP3094298
Good Luck,
:cool: :cool: :cool:
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
GU2300XTVS0: Random pattern on lights & keypad sometimes no responsive [Quiet Partner III] (Dishwasher Repair)
by ocallau 3/3/2024 9:59:15 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Hotpoint timer stalls in middle of opperation (Dishwasher Repair)
by Fidofax 2/15/2024 8:50:49 AM(UTC)
Dryer won’t stop after timer ends (Dryer Repair)
by ittssarah 2/4/2024 9:04:33 PM(UTC)
Clean light flashing 7 times: dishwasher run (Dishwasher Repair)
Belarus Guest 1/14/2024 9:56:27 AM(UTC)
evaporator fan runs all the time in FF compartment (Refrigerator & Freezer Repair)
by Guest 8/17/2023 6:27:55 AM(UTC)
Kenmore 592-89032 Dryer POWERS OFF mid-cycle on both timer and moisture settings (Dryer Repair)
by Guest 7/15/2023 6:11:04 AM(UTC)
Alternate timer control for older Maytag top load washer ModelLAT8210AAW (Washer Repair)
by Guest 7/7/2023 12:43:57 PM(UTC)
Ice Maker Not Making Ice At All Times (Refrigerator & Freezer Repair)
by danrclem 6/11/2023 6:52:52 PM(UTC)
