For about a year, my ice maker hasn't been working. I've replaced the inlet valve and also the icemaker (i didn't replace the wires it came with). I blew water from through the hose to the icemaker and it wasn't clogged up. What else can I try to get this to work? I am trying to avoid changing the wires because they gave me harnesses that don't fit into what I have already, it almost looks like I will have to take the wires out of the sidewall in order to change them.
Additional info, it used to cycle without water and due to financial issues we never fixed it but now that we are ok financially we want to fix it and now it doesn't even cycle which could be the reason it isn't filling up with water now.
Please please please help, filling up these ice cube trays everyday is way over rated, thanks.
Originally Posted by: sjrogers For about a year, my ice maker hasn't been working. I've replaced the inlet valve and also the icemaker (i didn't replace the wires it came with). I blew water from through the hose to the icemaker and it wasn't clogged up. What else can I try to get this to work? I am trying to avoid changing the wires because they gave me harnesses that don't fit into what I have already, it almost looks like I will have to take the wires out of the sidewall in order to change them.
Please please please help, filling up these ice cube trays everyday is way over rated, thanks. SJ, Is this the ice maker kit you orderred ? Part number: AP2984633
Based on the parts you've replaced, the best thing to do is review the kit instruction sheet, Determine which replacement harness to install, (circuitry in the new ice maker may be different than your original. You cannot change or repair the wires in the side wall, they are foamed in place and are a non repairable situation. Good Luck, :cool: :cool: :cool:
