Hi we've got an engineer here trying to fix the above machine but he can't get to the burners - can you please advise how to get to them?
Insert a flat screw driver in the top lock (in between the top panel and the top-front panel, left and right near the corners). There should be screws inside holding the top-front panel. Remove the bottom panel next to acces the burners.
