edkebel
#1 Posted : Monday, November 15, 2010 2:49:31 AM(UTC)
edkebel
Ice maker will dispense very little ice cubed or crushed , motor works it's as if its not getting moved to the chute.
Joe / APP Team
#2 Posted : Monday, November 15, 2010 8:33:17 AM(UTC)
Joe / APP Team
Ed,
Check the auger motor drive coupler, make sure it is not loose or stripped on the drive motor threaded shaft.
Part number: AP4363997
You'll need to remove the complete ice bin assembly from the unit to check.
While you have the bin out, empty the ice into a container and check the auger(corkscrew) and auger drive hub for proper alignment.
Part number: AP3045913
Also check the motor housing for level and perpendicular to the back wall of the freezer compartment.
Do you use a lot of ice ?
(icemaker produces 8 cubes per hour, approximately).
The less ice in the bin, the longer it takes to dispense.
Good Luck,
Whirlpool Ice Maker Not Producing - WRX986SIHZ00 Bought new 2018 (Refrigerator & Freezer Repair)
by dangerousdave 2/13/2023 8:18:25 AM(UTC)
Whirlpool Ice Maker WRX735SDBM ice melting in bin (Refrigerator & Freezer Repair)
by MQ1 12/27/2021 8:34:07 AM(UTC)
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 7/17/2021 11:48:06 AM(UTC)
Whirlpool Ice Maker Leaking (Refrigerator & Freezer Repair)
by WayneLee 3/7/2019 6:18:13 AM(UTC)
French door whirlpool ice maker (Refrigerator & Freezer Repair)
by Mattmaine1991 6/26/2017 7:40:45 AM(UTC)
Whirlpool Ice maker too warm, ice translucent (Refrigerator & Freezer Repair)
by jefferis 6/23/2017 6:59:46 PM(UTC)
Whirlpool Ice Maker Not Calling for Water (Refrigerator & Freezer Repair)
by hammerman02 1/6/2017 10:26:31 AM(UTC)
Whirlpool Ice Maker Not Making Ice (Refrigerator & Freezer Repair)
by hanginghelmet 5/8/2016 2:24:52 PM(UTC)
Whirlpool Ice Maker Diagnostic Question (Refrigerator & Freezer Repair)
by Four Winns 214 8/17/2015 7:44:03 PM(UTC)
Whirlpool Ice Maker not making ice (Refrigerator & Freezer Repair)
by turbotribes 8/1/2015 9:44:31 AM(UTC)
Whirlpool Ice maker (Refrigerator & Freezer Repair)
by RonColling 7/7/2015 8:54:36 AM(UTC)
Whirlpool Ice Maker Not Working - Low Voltage in Harness (Refrigerator & Freezer Repair)
by bthrem 4/7/2014 2:59:23 PM(UTC)
Broken Whirlpool Ice Maker Wires?? (Refrigerator & Freezer Repair)
by dvhumm 8/2/2013 6:59:31 AM(UTC)
Whirlpool Ice Maker Doesn't move (Refrigerator & Freezer Repair)
by IndyRick 7/13/2013 12:10:21 PM(UTC)
Whirlpool Ice Maker Not Working (Refrigerator & Freezer Repair)
by ARAYK 6/13/2013 8:11:31 AM(UTC)
