Ice maker will dispense very little ice cubed or crushed , motor works it's as if its not getting moved to the chute.
Originally Posted by: edkebel  Ice maker will dispense very little ice cubed or crushed , motor works it's as if its not getting moved to the chute. Ed, Check the auger motor drive coupler, make sure it is not loose or stripped on the drive motor threaded shaft. Part number: AP4363997
You'll need to remove the complete ice bin assembly from the unit to check. While you have the bin out, empty the ice into a container and check the auger(corkscrew) and auger drive hub for proper alignment. Part number: AP3045913
Also check the motor housing for level and perpendicular to the back wall of the freezer compartment. Do you use a lot of ice ? (icemaker produces 8 cubes per hour, approximately). The less ice in the bin, the longer it takes to dispense. Good Luck, :) :) :)
