Larry Golden
#1 Posted : Wednesday, November 5, 2008 12:59:34 PM(UTC)
Larry Golden
Door drops to a level almost to the floor upon opening. Return to closed position is jerky. This is not normal; can't recall when this started, but estimate approx 1 year ago.:(
#2 Posted : Wednesday, November 5, 2008 3:35:12 PM(UTC)
Hi Larry,
Most likely the problem is a bad door hinge(s). You have to remove the door from the oven and take it apart in order to replace them.
- The part number for the door hinge (they are identical) is AP4101089
Oven door problem (Oven Repair (including Ranges and Cooktops))
by TugCap 4/23/2016 12:48:34 PM(UTC)
Magic Chef Oven Door Problem (Oven Repair (including Ranges and Cooktops))
by chefkingoven 8/21/2012 5:48:14 PM(UTC)
by Hermans182 12/22/2010 8:37:31 AM(UTC)
by G. Wedlake 3/30/2009 9:26:46 AM(UTC)
The Dreaded Oven Door Problem! (Dishwasher Repair)
by Heymate 1/20/2009 10:16:24 PM(UTC)
Tappan Wall Oven Door Problem (Oven Repair (including Ranges and Cooktops))
by florenceshield 1/9/2009 6:35:19 PM(UTC)
oven door problems (Oven Repair (including Ranges and Cooktops))
by chopperbobby 11/3/2008 1:34:14 PM(UTC)
oven door problem (Oven Repair (including Ranges and Cooktops))
by lee-lester 9/21/2008 8:58:00 PM(UTC)
by lee-lester 9/21/2008 6:03:28 PM(UTC)
