Door drops to a level almost to the floor upon opening. Return to closed position is jerky. This is not normal; can't recall when this started, but estimate approx 1 year ago.:(
Hi Larry, Most likely the problem is a bad door hinge(s). You have to remove the door from the oven and take it apart in order to replace them. - The part number for the door hinge (they are identical) is AP4101089 Gene.
