Robin Mott
#1 Posted : Wednesday, November 5, 2008 6:47:51 AM(UTC)
Robin Mott
Washer will not stop filling up with water. I have changed out the water level switch. What could I try next.
magician59
#2 Posted : Wednesday, November 5, 2008 7:10:28 AM(UTC)
magician59
I would check to make sure the hose or tube from the tub to the switch is clear of any obstruction or restriction. Also check for debris in the water inlet valve. This could cause the valve to stick open. Depending on what that switch cost you, I'm sorry to say that they RARELY fail.
abadfish66
#3 Posted : Wednesday, November 5, 2008 7:19:14 AM(UTC)
abadfish66
Yep, cut off about 1 inch of that clear hose from the left of the tub, get a paper clip or something small and work it in and out of the hole of the tub to clear any obstruction, and reattach the hose. This generally happens if you don't use bleach very often. It's a good idea to do a hot wash with bleach every so often to get rid of the buildup in there.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
