My dryer makes a noise when I press the start button and shuts off in approximately 5 minutes. If I press the start button again it makes a buzzing noise and the machine won't turn on. If I wait about 15 minutes it will do the same thing. I checked the belt, drum rollers and idler pulley and they all look good. I haven't taken the blower wheel off or the drive motor. Thanks for your help.
These are classic signs of a failing motor, and I think replacing the machine rather than repairing it is the better option.
I purchased the motor and have received it already. When I installed it, the nut on the back side of the motor moves around even after I put the clamps on. I also took the blower wheel off an cleaned it. Now after putting it back together it makes a loud noise. If the motor is not installed should that nut be able to move around. Thank you for your help.
Originally Posted by: Rob S  I purchased the motor and have received it already. When I installed it, the nut on the back side of the motor moves around even after I put the clamps on. I also took the blower wheel off an cleaned it. Now after putting it back together it makes a loud noise. If the motor is not installed should that nut be able to move around. Thank you for your help. I fixed the problem. The motor wasn't in the groove in the back. Once in the machine works like it is brand new.
Great, thanks for the update and glad you got it going.
