Rob S
#1 Posted : Monday, November 8, 2010 9:44:37 AM(UTC)
Rob S
My dryer makes a noise when I press the start button and shuts off in approximately 5 minutes. If I press the start button again it makes a buzzing noise and the machine won't turn on. If I wait about 15 minutes it will do the same thing.
I checked the belt, drum rollers and idler pulley and they all look good. I haven't taken the blower wheel off or the drive motor.
Thanks for your help.
sidfink43
#2 Posted : Thursday, November 11, 2010 5:22:46 PM(UTC)
sidfink43
These are classic signs of a failing motor, and I think replacing the machine rather than repairing it is the better option.
Rob S
#3 Posted : Friday, November 12, 2010 2:48:49 PM(UTC)
Rob S
I purchased the motor and have received it already. When I installed it, the nut on the back side of the motor moves around even after I put the clamps on. I also took the blower wheel off an cleaned it. Now after putting it back together it makes a loud noise. If the motor is not installed should that nut be able to move around. Thank you for your help.
Rob S
#4 Posted : Saturday, November 13, 2010 10:00:07 AM(UTC)
Rob S
I fixed the problem. The motor wasn't in the groove in the back. Once in the machine works like it is brand new.
sidfink43
#5 Posted : Saturday, November 13, 2010 10:24:05 AM(UTC)
sidfink43
Great, thanks for the update and glad you got it going.
Dryer stops after 5 minutes (Dryer Repair)
by wetlabs 11/14/2014 12:18:52 PM(UTC)
Dryer stops after 5 minutes, restarts fine (Dryer Repair)
by Hydrophilia 11/1/2009 8:25:35 AM(UTC)
