When Dryer Is Turned On It Starts To Heat Up. After A Few Minutes The Heat Shuts Off. The Dryer Continues To Run But The Timer Will Not Move
Originally Posted by: BILLY D  When Dryer Is Turned On It Starts To Heat Up. After A Few Minutes The Heat Shuts Off. The Dryer Continues To Run But The Timer Will Not Move THERMAL FUSE HAS BEEN REPLACED
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
