dswalla
#1 Posted : Wednesday, November 3, 2010 7:33:36 PM(UTC)
dswalla
Our Estate washing machine started leaking from the bottom front area. I only noticed it after a load was done. It didn't appear to leak while washing or filling only during the draining cycle. The leak is worse now and although cycle seems done, you can shake machine and tell there is still water inside but you can't see water in the tub. It finally drains out but takes 3-5 minutes and puddle of water gets bigger. Do you think it might be the pump? And how hard is it to repair ourselves?
#2 Posted : Wednesday, November 3, 2010 11:12:24 PM(UTC)
Most likely the problem is a bad water pump. In order to access the part you have to remove the washer cabinet. The disassembly instructions are attached to the reply.
- The water pump Part number: AP2907492
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL TAWS700RQ1 Automatic Washer | AppliancePartsPros.com
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 21 time(s).
How to remove the pump.doc (25kb) downloaded 10 time(s).
Washer leaks at end of cycle only (Washer Repair)
by Orvilejulius 8/13/2023 8:42:38 PM(UTC)
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 6/2/2022 8:57:54 PM(UTC)
Washer leaks water only when using water outside (Washer Repair)
by MattWasPele 9/21/2020 9:46:26 AM(UTC)
Maytag washer leaks on power wash cycle (Washer Repair)
by homeland1984 8/1/2020 8:44:37 AM(UTC)
GE Washer leaks after sitting? (Washer Repair)
by redjada 4/11/2018 2:46:00 PM(UTC)
Washer leaks on front door (Washer Repair)
by robertkral1 10/4/2017 11:41:47 AM(UTC)
Washer leaks and fills drain tray (Washer Repair)
by boberp 3/13/2016 7:27:42 AM(UTC)
Kitchenaid Dishwasher Leaks at Float (Dishwasher Repair)
by macd2x 11/8/2015 7:29:26 AM(UTC)
Washer leaks (Washer Repair)
by DIYChallenged 9/14/2015 10:15:27 AM(UTC)
Dishwasher leaks front door (Dishwasher Repair)
by kbratto 8/26/2015 9:53:11 AM(UTC)
New Maytag top load Washer Leaks in Front (Washer Repair)
by Gadgetmonster 7/10/2015 9:11:53 AM(UTC)
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 6/22/2015 5:52:31 PM(UTC)
Kenmore portable washer leaks (Washer Repair)
by Jimisand 3/9/2015 10:38:25 AM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/25/2015 9:47:32 PM(UTC)
Washer Leaks while filling up .. Large Loads Only (Washer Repair)
by martynva 7/26/2014 3:17:06 AM(UTC)
