Myrtis
#1 Posted : Wednesday, November 3, 2010 9:05:59 AM(UTC)
Myrtis
I have a RBD305PDS14 double oven, the bottom oven works, but the broiler is not working... I have replaced the element, and sensor. Please help
#2 Posted : Thursday, November 4, 2010 4:44:26 AM(UTC)
Here is your parts breakdown
Replacement parts for WHIRLPOOL RBD305PDS14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper | AppliancePartsPros.com
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
Since you have replaced some parts, I am assuming that the unit has already been powered down and back up. This is usually the first place to start with microprocessor controlled devices as often all that is needed is for the processor to reset.
You will see in the parts that there is a thermal fuse (Item 37 in Section 1)
If you then look at the manual Page 7-4, you will see that the fuse is wired a couple different ways depending on whether it is a self clean or not. Although it really does not show it very clearly, it could be that this thermal fuse is just in the broil circuit for a non-self clean unit.
If this is the case my guess is that it is blown.
Remove power from the unit, remove one wire from the fuse, it should be 0 ohms.
If the fuse and wiring is good then odds are the control board is toast.
Whirlpool WRF535SWHZ07 Won't Program Control Board (Refrigerator & Freezer Repair)
by Guest 7/5/2024 1:43:28 AM(UTC)
WRF989SDAM03 Whirlpool fridge making ice very slowly (Refrigerator & Freezer Repair)
by BlueWRXPride 6/20/2024 5:24:45 PM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool fridge WRF560SFYM02 (Refrigerator & Freezer Repair)
by Guest 6/15/2024 5:02:08 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool cont. clean stove SF330 PERN6 (Oven Repair (including Ranges and Cooktops))
by bruce.kolozy@att.net 6/10/2024 2:55:08 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
Whirlpool wtw500dw1 won't fill (Washer Repair)
by Guest 6/9/2024 4:14:40 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool LA5700XTN0 won't agitate (Washer Repair)
by Kyou 6/2/2024 5:13:20 PM(UTC)
Whirlpool Flame Cuts off After 5-10 seconds (Dryer Repair)
by Guest 6/1/2024 8:00:29 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Fridge odor (Refrigerator & Freezer Repair)
by Guest 5/14/2024 4:46:42 AM(UTC)
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
