:confused: well no oven Ireplaced ignitor and then checked gas saftey valve and have no continuity across it i have power in and out of ignitor but nothing across saftey valve
If there is no continuity across the gas valve terminals then the gas valve has to be replaced. - The part number for the gas valve is AP3422382 Gene.
I sorta figured that out but i needed a boot to spend that much more :) thanx again
