litenin32
#1 Posted : Tuesday, October 28, 2008 3:57:17 PM(UTC)
litenin32
:confused: well no oven Ireplaced ignitor and then checked gas saftey valve and have no continuity across it i have power in and out of ignitor but nothing across saftey valve
#2 Posted : Wednesday, October 29, 2008 3:54:55 PM(UTC)
If there is no continuity across the gas valve terminals then the gas valve has to be replaced.
- The part number for the gas valve is AP3422382
litenin32
#3 Posted : Wednesday, October 29, 2008 4:48:33 PM(UTC)
litenin32
I sorta figured that out but i needed a boot to spend that much more :) thanx again
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
How to diagnose Thermador gas oven PG366BS not heating? (Oven Repair (including Ranges and Cooktops))
by Guest 4/12/2023 12:28:01 PM(UTC)
Frigidare gas oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/19/2023 10:34:40 AM(UTC)
Whirlpool Gas Oven - GW397LXUS06 (Oven Repair (including Ranges and Cooktops))
by Guest 3/16/2023 6:39:44 PM(UTC)
WFG231LVQ0 Gas Oven F2 Code (Oven Repair (including Ranges and Cooktops))
by jwclteer 2/1/2023 12:42:38 PM(UTC)
Gas oven won’t light (Oven Repair (including Ranges and Cooktops))
by Guest 12/22/2022 1:10:46 PM(UTC)
GE gas oven not maintaining temperature after preheat completes (Oven Repair (including Ranges and Cooktops))
by Guest 12/2/2022 7:33:59 PM(UTC)
Kitchen aid gas oven won’t heat up (Oven Repair (including Ranges and Cooktops))
by Guest 11/24/2022 4:29:09 AM(UTC)
KitchenAid KGRS807SSS02 30" Freestanding Gas Oven Convection - F6 E0 Lost Communications Error (Oven Repair (including Ranges and Cooktops))
by Matthedges 8/9/2022 4:59:40 AM(UTC)
Whirlpool W10198618A Gas Oven Won’t stay lit (Oven Repair (including Ranges and Cooktops))
by Guest 1/10/2022 3:49:35 PM(UTC)
gas oven blowing out (Oven Repair (including Ranges and Cooktops))
by searkcraig 12/25/2021 8:04:53 AM(UTC)
gas oven ignitor cost (Oven Repair (including Ranges and Cooktops))
by Guest 10/30/2021 5:43:49 AM(UTC)
Whirlpool gas oven lights but won't heat to temperature (Oven Repair (including Ranges and Cooktops))
by mikepol2 10/28/2021 5:13:06 AM(UTC)
GE Gas Oven Control panel blank (Oven Repair (including Ranges and Cooktops))
by sjohnson1161 3/17/2021 6:23:41 PM(UTC)
