lloydrealestate
#1 Posted : Thursday, October 28, 2010 4:40:37 PM(UTC)
lloydrealestate
This is a coin op dryer and should run for 30 minutes. For some reason it started cutting out after about 10 minutes. I was told that it was the timer but the time is still running when it cuts out(stop). I have replaced the timmer as that is what an appliance repair man recommended. The dryer still cuts out after 10 minutes. I have checked the exhaust pipe and that is clear of lint. Any ideas? Thanks.
Joe / APP Team
#2 Posted : Friday, October 29, 2010 1:50:58 PM(UTC)
Joe / APP Team
Lloyd,
Just an educated guess, but the next step would be to check the motor overload switch.
If the motor is overheating, due to internal wear, or is blocked and clogged with debris or lint, the switch opens and turns off the motor.
Based on your information, that would be the next place to investigate.
lloydrealestate
#3 Posted : Saturday, October 30, 2010 3:39:40 AM(UTC)
lloydrealestate
Where would I find the motor overload switch on the Maytag dryer
Joe / APP Team
#4 Posted : Monday, November 1, 2010 7:32:04 AM(UTC)
Joe / APP Team
The motor overload switch is located inside the motor housing.
It appears as a little black box, with two wires attaching to the centifugal switch,on the motor.
It is not available as an individual part, you'll need to replace the complete motor.
Part number: AP4290649
Good Luck,
:cool: :cool: :cool:
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Maytag gas dryer flame shuts off (Dryer Repair)
by Guest 11/13/2022 11:35:33 AM(UTC)
Maytag Gas Dryer Model # MGDB400VQ0 (Dryer Repair)
by lazyacre 3/29/2020 5:29:29 AM(UTC)
Maytag gas dryer won’t ignite (Dryer Repair)
by Jmuk_98 6/30/2018 9:47:34 AM(UTC)
Maytag gas dryer console (Dryer Repair)
by thorning 5/5/2017 4:32:55 AM(UTC)
Maytag Gas Dryer Burner won't stay lite (Dryer Repair)
by tseibring 1/26/2017 2:48:45 PM(UTC)
Maytag gas dryer not heating correctly (Dryer Repair)
by ifix325 12/10/2014 6:37:45 AM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
Maytag gas dryer belt keeps coming off (Dryer Repair)
by Blurr 10/29/2014 11:17:27 AM(UTC)
Maytag Gas Dryer Will Not Stay Hot (Dryer Repair)
by jschrote 8/27/2014 6:07:26 PM(UTC)
Maytag gas dryer heats only on high (Dryer Repair)
by broooklyn 4/9/2014 10:55:14 AM(UTC)
Maytag gas dryer - flame shuts off early (Dryer Repair)
by Dcarterlaw 4/1/2014 4:52:58 PM(UTC)
Maytag Gas Dryer Timer not Adance in Auto Dry (Dryer Repair)
by modcar40 3/4/2014 3:01:27 PM(UTC)
