toolguy47
#1 Posted : Wednesday, October 27, 2010 10:09:17 AM(UTC)
toolguy47
My dryer seems to heat up excessively when drying a load of clothes. They are almost too hot to touch when taking them out. I thought at first that the vent may be clogged, but I cleaned it out and it still does it. Any ideas on what might be the culprit? Thanks for any help.
Joe / APP Team
#2 Posted : Wednesday, October 27, 2010 10:39:35 AM(UTC)
Joe / APP Team
Toolguy,
Did you check for a shorted heater element ?
It may have broke and shorted to the element casing.
Do you have a thermometer or temperature meter so you can check for 155(+/-10%) degrees at the exhaust vent on the dryer, with the vent off ?
That would be the next step, were it me.
Good Luck,
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Whirlpool dryer overheating, replaced thermostats (Dryer Repair)
by rastoma 10/18/2017 6:29:27 PM(UTC)
Kenmore Dryer Overheating and weak (Dryer Repair)
by Cardiaccat 9/3/2017 9:25:50 AM(UTC)
Dryer Overheating When Not Running (Dryer Repair)
by Chris McCain 4/5/2017 8:06:45 AM(UTC)
Maytag Dryer Overheating (Dryer Repair)
by atem2144 10/28/2016 12:34:41 PM(UTC)
dryer overheating (Dryer Repair)
by dave3712 10/15/2016 8:16:37 AM(UTC)
Estate Dryer Overheating. I suspect hot air leaking from drum (Dryer Repair)
by Picklefall1 9/12/2016 8:13:23 PM(UTC)
Kenmore Dryer Overheating (Dryer Repair)
by atem2144 8/17/2016 1:41:31 PM(UTC)
by dadunn60 3/1/2016 9:43:04 AM(UTC)
by sfhutchi 2/28/2015 1:57:08 PM(UTC)
Whirlpool Dryer Overheating (Dryer Repair)
by TravisC 1/17/2015 11:13:36 AM(UTC)
by HawtDog 1/12/2015 1:59:21 PM(UTC)
Duet Dryer Overheating (Dryer Repair)
by Snarlybarley 11/20/2013 6:44:40 AM(UTC)
Dryer Overheating When Turned Off (Dryer Repair)
by Jeffshumaker 10/13/2013 4:27:05 PM(UTC)
