hi my microwave is making a lot of continueos beeps while running also when off , heats ok but when cycle is done it starts over by itself ocationally . unpluged for a day but still does the same thing what could be the problem?
do you think it could also be the touch pad
Touch pad problems usually manifest as non-responses; i.e. when you press a touch pad button, you either get sporatic responses, or none at all.
