Recently purchased a used washer that is now not working.
Frigidaire Affinity ATF6000ES1. Error = E47.
In normal operation the washer will not spin, or sometimes it will spin but not fast.
In diagnostic mode, turning knob 6 clicks to spin cycle, Washer does enter into fast spin mode and works great for about 2 minutes. Then stops and get Error Code 47. So obviously the fast final spin cycle does work, but not in normal operation (just in diagnostic operation).
Should I first check for a clogged filter and drain pump? Is there anything else I should check to see if there is a clog/blockage.
Given that I get Error E47, will a new locking unit fix the problem. Is this the correct part Part Number: AP4455026, Made by FRIGIDAIRE.
In short, what is the best means to proceed to repair this washer.
Thanks for any help and comments.
Originally Posted by: amarkscpa ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Recently purchased a used washer that is now not working. Frigidaire Affinity ATF6000ES1. Error = E47. In normal operation the washer will not spin, or sometimes it will spin but not fast. In diagnostic mode, turning knob 6 clicks to spin cycle, Washer does enter into fast spin mode and works great for about 2 minutes. Then stops and get Error Code 47. So obviously the fast final spin cycle does work, but not in normal operation (just in diagnostic operation). Should I first check for a clogged filter and drain pump? Is there anything else I should check to see if there is a clog/blockage. Given that I get Error E47, will a new locking unit fix the problem. Is this the correct part Part Number: AP4455026, Made by FRIGIDAIRE. In short, what is the best means to proceed to repair this washer. Thanks for any help and comments. I don't know the AP#, but this is the Frigidaire part# 131763202 Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
