BDR89
#1 Posted : Sunday, October 24, 2010 5:01:55 AM(UTC)
BDR89
I have the tech sheet but I'm not sure how to do it
magician59
#2 Posted : Monday, October 25, 2010 7:09:20 AM(UTC)
magician59
Just follow the directions, step by step, on the tech sheet. No need to rush through it. What are you trying to diagnose?
BDR89
#3 Posted : Monday, October 25, 2010 6:41:58 PM(UTC)
BDR89
I keep getting an F11 code. The washer will go through the complete cycle but will not spin the clothes out. Any ideas?? I see a lot of posts say it is in the motor control unit
magician59
#4 Posted : Monday, October 25, 2010 6:55:48 PM(UTC)
magician59
It sounds like a motor drive control to me...does it happen regardless of which cycle it's in?
BDR89
#5 Posted : Monday, October 25, 2010 7:02:52 PM(UTC)
BDR89
Yes happens in all cycles?? Is the motor control unit a safe bet?? Thanks appreciate the help. John
magician59
#6 Posted : Monday, October 25, 2010 7:16:20 PM(UTC)
magician59
I'm really more familiar with Maytags; it's a fairy common failure on them. If it were a door lock problem, it wouldn't go through the cycle. It just may be a good idea to hire a pro for the diagnosis, given the replacement cost of the machine.
BDR89
#7 Posted : Monday, October 25, 2010 7:20:51 PM(UTC)
BDR89
I would like to take a crack at it. It sounds like your pretty sure that the motor control unit is a good place to start. If that's doesn't fix it where would you look next ?? Thanks John
BDR89
#8 Posted : Tuesday, October 26, 2010 3:02:04 AM(UTC)
BDR89
I ran it again last night and it now shows a F1 code now. It still did not spin out the clothes. Need help!! Should i still replace the motor control unit??
magician59
#9 Posted : Tuesday, October 26, 2010 7:15:27 AM(UTC)
magician59
F1 usually refers to the main control board.
