I have the tech sheet but I'm not sure how to do it
Just follow the directions, step by step, on the tech sheet. No need to rush through it. What are you trying to diagnose?
I keep getting an F11 code. The washer will go through the complete cycle but will not spin the clothes out. Any ideas?? I see a lot of posts say it is in the motor control unit
It sounds like a motor drive control to me...does it happen regardless of which cycle it's in?
Yes happens in all cycles?? Is the motor control unit a safe bet?? Thanks appreciate the help. John
I'm really more familiar with Maytags; it's a fairy common failure on them. If it were a door lock problem, it wouldn't go through the cycle. It just may be a good idea to hire a pro for the diagnosis, given the replacement cost of the machine.
Originally Posted by: magician59 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I'm really more familiar with Maytags; it's a fairy common failure on them. If it were a door lock problem, it wouldn't go through the cycle. It just may be a good idea to hire a pro for the diagnosis, given the replacement cost of the machine. I would like to take a crack at it. It sounds like your pretty sure that the motor control unit is a good place to start. If that's doesn't fix it where would you look next ?? Thanks John
I ran it again last night and it now shows a F1 code now. It still did not spin out the clothes. Need help!! Should i still replace the motor control unit??
F1 usually refers to the main control board.
