Can someone help me find out what error codes FR and F-5 are for thermador dbl oven I cant locate anywhere.:)
Rank: Administration
Welcome to the forum!
Thermador S302TS Error Codes
FR Code:
Cause 1: Invalid door lock switch status (lower oven). Example: Defective or jammed lower oven latch switches. Corrective Action: Make sure lower oven latch switches are operating properly. Cause 2: Communication error detected by main relay board. Example: Bad display head. Corrective Action: Check all power and communication connections to the oven relay boards and the display head. Cause 3: Element supervisor is disabled (lower oven). Example: Intermittent lower oven temperature sensor or bad lower oven relay board. Corrective Action: Replace lower oven temp sensor. If control still displays FR, replace lower oven relay board.
F5 Code:
Cause: Element supervisor is disabled (single / upper oven). Example: Intermittent single / upper oven temperature sensor or bad main relay board. Corrective Action: Replace single / upper oven temperature sensor. If control still displays F5, replace main relay board.
Hope this helps. See you around.
