repairman08
#1 Posted : Saturday, October 25, 2008 11:08:56 AM(UTC)
repairman08
Can someone help me find out what error codes FR and F-5 are for thermador dbl oven I cant locate anywhere.:)
Admin / APP Team
#2 Posted : Saturday, October 25, 2008 1:24:36 PM(UTC)
Admin / APP Team
Rank: Administration
Welcome to the forum!
Thermador S302TS Error Codes
FR Code:
Cause 1: Invalid door lock switch status (lower oven). Example: Defective or jammed lower oven latch switches. Corrective Action: Make sure lower oven latch switches are operating properly.
Cause 2: Communication error detected by main relay board. Example: Bad display head. Corrective Action: Check all power and communication connections to the oven relay boards and the display head.
Cause 3: Element supervisor is disabled (lower oven). Example: Intermittent lower oven temperature sensor or bad lower oven relay board. Corrective Action: Replace lower oven temp sensor. If control still displays FR, replace lower oven relay board.
F5 Code:
Cause: Element supervisor is disabled (single / upper oven). Example: Intermittent single / upper oven temperature sensor or bad main relay board. Corrective Action: Replace single / upper oven temperature sensor. If control still displays F5, replace main relay board.
Hope this helps. See you around.
LG Dryer DLGY1702VE no error codes (Dryer Repair)
by Lisssasue 7/17/2023 10:41:37 AM(UTC)
Kenmore Elite Washer error codes (Washer Repair)
by Cenzo 3/23/2023 12:58:19 PM(UTC)
Kenmore washer error codes (Washer Repair)
by Guest 3/5/2023 7:00:21 AM(UTC)
GE Refrigerator diagnostic mode error codes (Refrigerator & Freezer Repair)
by Guest 1/22/2023 10:11:53 AM(UTC)
Kennmore Elite Top Load Washer - MHK62125813 - Error Codes (Washer Repair)
by maxxam864 1/4/2023 12:11:00 PM(UTC)
Error Codes on lg dishwasher LDF5545st (Dishwasher Repair)
by Guest 7/25/2022 10:57:38 AM(UTC)
GE GTW330ASK1WW odd behavior and multiple error codes for lid lock (Washer Repair)
by petermbooth 6/3/2022 5:11:39 PM(UTC)
Frigidaire gallery error codes (Oven Repair (including Ranges and Cooktops))
by Guest 5/9/2021 9:55:31 AM(UTC)
Does anyone know how to clear error codes on Bosch Washer (Washer Repair)
by bmoney37 6/12/2020 9:35:37 PM(UTC)
Whirlpool Duet Steam Error Codes (Dryer Repair)
by etamunupe 3/28/2020 5:09:00 AM(UTC)
front load washer error codes (Washer Repair)
by scully61 11/19/2018 5:44:51 AM(UTC)
Jenn-air Gas Range Error codes (Oven Repair (including Ranges and Cooktops))
by uncledave11 3/29/2018 11:48:39 AM(UTC)
No error codes (Oven Repair (including Ranges and Cooktops))
by docnpat 2/16/2018 8:08:11 PM(UTC)
Kitchen aid not cleaning dishes have error codes (Dishwasher Repair)
by Randall1803 11/13/2016 6:55:35 PM(UTC)
Help with Maytag Washing Machine Error Codes (Washer Repair)
by Gjohnlue 7/8/2016 3:58:06 PM(UTC)
