bmoore201
#1 Posted : Saturday, October 23, 2010 7:46:50 AM(UTC)
bmoore201
My fairly new Whirlpool Accubake oven/range shut down completely while baking and will not come back on. The digital display for all oven use completely shut down. The stove top works fine but no oven. Anybody know what is going on?
#2 Posted : Sunday, October 24, 2010 1:53:33 AM(UTC)
A model number may help others help you
Model Number Locator
Could be a number of things.
Many units have an overheat thermostat attached either to the top or back of the oven which can cause problems.
If the oven is indicating that it is ready when it is not it could be the oven sensor.
There are other possibilities depending on the wiring.
Here is a good site with basice stove repair help.
http://www.applianceaid.com/erange.html
bmoore201
#3 Posted : Monday, October 25, 2010 12:32:22 PM(UTC)
bmoore201
Thanks for the reply. Where would the model # be locate? I looked inside the door and located what appeared to be a serial number. Nothing works on the control panel not even the clock the screen has no power. the only thing that works is the stove top.
#4 Posted : Monday, October 25, 2010 1:14:57 PM(UTC)
Here is the model number locator from the Whirlpool website
http://www.whirlpool.com/service/modelnumber.jsp
bmoore201
#5 Posted : Monday, October 25, 2010 1:24:52 PM(UTC)
bmoore201
Found the model # RF362lxts
#6 Posted : Monday, October 25, 2010 1:52:56 PM(UTC)
Replacement parts for RF362lxts models | AppliancePartsPros.com
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/5feedbe46138625985256aa1005ef62c/$FILE/8178042.pdf
Unit does show a thermal fuse Item 26 in Section 3, but I think it is the one for just the broil element.
If you look at the wiring diagram Page 6-1 it also does show a none resettable fuse as part of the brown wire going to the control board.
Not sure I totally trust the wiring diagram as it shows a separate power supply which I cannot find in the parts. They may well still have an inline fuse built into one of the wires.
bmoore201
#7 Posted : Monday, October 25, 2010 2:52:34 PM(UTC)
bmoore201
So a non resetable fuse has to be replaced? Would that fuse cause the whole display board to go out? Thanks for the manual by the way. According to Whirlpool agent on phone such a manual does not exist. go figure. Also this type of problem doesn't officially exist with these units despite the many threads that say it does.
#8 Posted : Monday, October 25, 2010 3:49:35 PM(UTC)
[COLOR="Blue"]So a non resetable fuse has to be replaced? Would that fuse cause the whole display board to go out?[/COLOR]
Not 100% sure on this but since it shows it in a power supply line I would say yes. Not even sure that you have one but it is well worth a look.
Often they are just a bulge in a wire.
bmoore201
#9 Posted : Monday, October 25, 2010 3:59:10 PM(UTC)
bmoore201
Thanks for your help
Guest (10)
Kenmore gas range oven won't work (Oven Repair (including Ranges and Cooktops))
by shirleyjones 12/14/2016 10:41:41 AM(UTC)
oven won't work properly randomly (Oven Repair (including Ranges and Cooktops))
by miklos 9/29/2016 2:36:35 AM(UTC)
by b2bq 6/11/2014 9:26:03 AM(UTC)
Kenmore oven won't work. Stovetop still works but neither bake nor broil will heat (Oven Repair (including Ranges and Cooktops))
by dangole104 2/18/2013 7:22:38 PM(UTC)
GE Built-In Gas Oven Won't Work Even After Replacing Parts (Oven Repair (including Ranges and Cooktops))
by kimpossible 1/17/2013 4:30:57 PM(UTC)
Oven won't work (Oven Repair (including Ranges and Cooktops))
by Hock 6/20/2012 10:30:03 AM(UTC)
Oven won't work after the self cleaning cycle (Oven Repair (including Ranges and Cooktops))
by sluggermike 11/24/2011 12:37:19 AM(UTC)
Kitchen Aid oven won't work after cleaning cycle (Oven Repair (including Ranges and Cooktops))
by geopharmer 3/9/2011 7:18:14 AM(UTC)
Denman please help! Oven won't work. (Oven Repair (including Ranges and Cooktops))
by johnrp99 2/23/2011 12:38:43 PM(UTC)
Maytag Gemini Upper Oven won't work (Oven Repair (including Ranges and Cooktops))
by mleslie 2/21/2011 5:50:47 PM(UTC)
Oven won't work after self-clean. (Oven Repair (including Ranges and Cooktops))
by tandg98 2/21/2011 5:19:51 PM(UTC)
Replaced bake element,but oven won't work (Oven Repair (including Ranges and Cooktops))
by ant1828 2/19/2011 12:52:32 PM(UTC)
Clock & numbers dimming now oven won't work (Oven Repair (including Ranges and Cooktops))
by pennym363 12/21/2010 5:05:46 PM(UTC)
The bake button of walloven won't work. (Oven Repair (including Ranges and Cooktops))
by jakyl07 8/11/2010 8:42:16 AM(UTC)
Whirlpool oven won't work!! (Oven Repair (including Ranges and Cooktops))
by serenity of three 7/28/2010 2:37:15 PM(UTC)
