I have a kenmore front load stacking washer that will not drain. I have checked the hoses and replaced the pump. It is still not draining. Any ideas? Thank you.
Originally Posted by: brcaldwe  I have a kenmore front load stacking washer that will not drain. I have checked the hoses and replaced the pump. It is still not draining. Any ideas? Thank you. BR, We'd have a better idea if you get us a proper model number. Anything at this point would be a guess and probably not correct. Thanks, :confused: :confused: :confused:
model # 26-40412 item # 02640412000
Originally Posted by: brcaldwe  model # 26-40412 item # 02640412000 BR, Still incorrect, that's not a model number either. The Model number tab should be on front panel when you open the door Should look something like this : 123.45678900 Please try again, Thanks, :cool: :cool: :cool:
found it Model# 970-c45042-00 Serial# xc51718724
Originally Posted by: brcaldwe  found it Model# 970-c45042-00 Serial# xc51718724 BR, We still have a prolem with that serial number, But As best I can tell, Since you have a new pump, and it still wont drain, I would have to suspect a loose or broken wire from the pump to the timer, or a bad timer. That's the best we can do, until we get a proper model number so we can access the technical information and parts lists,for more accurate diagnosis and repair. Thanks, :) :) :)
